4001 doorbell camera along with 4 pro5 cameras and a 4540 hub
  • 4 Replies
  • 1598 Views
boneman4069
Hi, just purchased a 4001 doorbell camera along with 4 pro5 cameras and a 4540 hub, thinking I'd put all the cameras on the hub to avoid subscription. . . Silly me!  The free trial just ended on the doorbell and it's now useless .  . And when I try to add it to the hub I only get the option to add it to wifi.
I found, on here, that the ability to connect to hub is coming in a future software upgrade . . . Hmmm . . .maybe?
Is there any way around this?
I had also thought to use one of my cameras on a separate wifi network (starlink) and use that cam to guard my camper . . Will this be seen as another location and incur a separate subscription fee?
Thanks all
The only workaround is to get a single camera subscription until they roll out smarthub support for the camera.
That depends on whether you set up a second location in the app, or not.
You'd lose some flexibility with only one location (simplest not to use geofencing when the camper isn't at your home, and the three modes would be shared across your home and the camper).
boneman4069
Thanks Stephen, I would be using the 4th cam in the same app as when out camping I also want to keep a  eye on home. Thanks
boneman4069
Can't see the front door cam listed in the subscription section? Is it somewhere else?
I do see all the other devices with "free trial" beside them.  .
boneman4069
Found it, thanks again Stephen
