static noise on ultra 4K camera
I purchased the 4K cameras about a month ago. One of the cameras now how a loud static noise when it is turned on or recording. Any suggestions of how to fix this or do I need to return the camera for a replacement? My other 3 4K cameras are perfectly fine. I chaged out the battery as well as brought the camera to within 10 feet of the base station and nothing worked to remove the loud static noise.
Sounds like a return or warranty issue
Jandmc,
Try swapping the location of the problem camera with a camera that is behaving as expected to see if the issue follows the camera or the location. That will help isolate the issue.
You may need to remove and resync the camera. Be sure all permissions for the app in the phone settings are enabled.
Accessing Local Storage
