static noise on ultra 4K camera
  • 6 Replies
  • 2754 Views
  • 5 In Conversation
Jandmc
I purchased the 4K cameras about a month ago. One of the cameras now how a loud static noise when it is turned on or recording. Any suggestions of how to fix this or do I need to return the camera for a replacement? My other 3 4K cameras are perfectly fine. I chaged out the battery as well as brought the camera to within 10 feet of the base station and nothing worked to remove the loud static noise.
6 REPLIES 6
Sounds like a return or warranty issue
Jandmc,
Try swapping the location of the problem camera with a camera that is behaving as expected to see if the issue follows the camera or the location. That will help isolate the issue.
hfjj
hi, I have some trouble with my arlo.there is no notification to my app in the armed model.Even i have set everything with motion detected send notification to my app and email. In fact there is nothing to my app and email. please help me
You may need to remove and resync the camera. Be sure all permissions for the app in the phone settings are enabled.
Jandmc
I contacted Arlo and we attempted to trouble shoot the camera...unfortunately it is a defective camera and needs to be sent back.
hfjj
In this process,I have reboot the basa , remove and then resync the camera. I am sure all permission for the app in the phone ara enabled. Because i have open the notifition sent to my phone and email when the motion detectied. finally, my arlo system is up to data.
  • 6 Replies
  • 2755 Views
  • 5 In Conversation
