Hi,
What are the old Arlo brand accessories compatible with the new Arlo Ultra 4K cameras?
Ok, for the skins was "niet". I have read it already in a post.
Then,
- The batteries ?
- The brackets / fixings?
- Permanent power supplies (cable, plug, charger, power, etc.)?
- Solar panels (power)?
There would be accessories that would not Arlo brand but compatible with the Arlo Ultra? (Skin,...)
Thank in advance for yours replies.
Greetings from France, regards
Dom
The only thing that is compatible with the Ultra system that I know of are the wall mounts, (screw in type, not magnetic).
The Ultra camera is much larger than the older cameras so the older skins will not fit.
The batteries are larger and not compatible,
The magnetic mount is completely different and the Arlo camera no longer has the magnet in the camera.
The electrical connectors from the power cables and solar panels are now magnetic, not plug in.
The solar panel now has the cable permanently attatched in the panel and uses a magnetic connector.
The battery chargers are different to accomodate the larger battery.
Brian
Brian
Hi Brian,
Thank you ...
« The solar panel now has the cable permanently attatched in the panel and uses a magnetic connector. »
Is there a reference for this product?
Regards
dom
here is the product on Amazon where I purchased mine.
Brian
Hi,
flute, this reference is not present on the site fr d'amazon!
regards
dom
They were just released in the US a few weeks ago so it might not be available yet outside the US. You might have to wait a few weeks more.
Brian
Accessing Local Storage
