  • 2 Replies
  • 647 Views
Yauheni
since I live in Belarus
my tariff plan doesn’t work
but before that I received notifications on the phone
the video was sent to the SD card
after the firmware, the camera stopped sending notifications
Spoiler
error :AC power has been disconnected from your Arlo device. Activity Zones are currently disabled
AC power connection gives nothing
the camera is constantly on to the VMA5600
maybe someone can help  camera connection via vpn to start working tariff plan or at least notifications started to come
and without these functions, the camera is not worth the money :(((((
brh
@Yauheni,
I dount know about subscription plans in your country, but is your camera detectiong motion? On the Devices page when you walk in front of the camera does the motion detection icon turn amber? If not try this:
1) Remove the camera from your account.
2) Power cycle your hub.
3) Add the camera back to your account.
Hopefully, your camera will now detect motion and send notifications. This workaround worked for me.
Brian
Yauheni
cameras and the base was untied from the account
camera and base did a reset
after that I set everything up again
sees movement and writes video on SD
only no notifications
tried on two different phones
if you connect the camera is not ultra hd(arlo,arlo pro, arlo pro 2) everything is working
3 months the camera worked fine until updated
today put the latest update the same :(((((
  • 2 Replies
  • 648 Views
