microSD, SDHC, or SDXC for Alro Ultra - Size Limits, Speed Requirements and Segmentation
  • 2 Replies
  • 5929 Views
Obi1BonJovi
I see than an existing article explains that "...the Arlo SmartHub accepts microSD cards, SDHC, or SDXC. We recommend that you use a microSD card with a minimum of 16 GB capacity, Speed Class 10, UHS1, V10. The Arlo SmartHub supports up to class 10 UHS-3 V90 class microSD cards."
A handful of important questions that I haven't found answered in the forum:
1.) For local recording of up to (4) Arlo Ultra Camera's in 4K mode, what is the *minimum* speed requirement on the card?
2.) Is there a ceiling on the maximum card size that Arlo's SmartHub can accomodate (i.e. 128GB, 256GB)?
3.) For *each* Arlo Ultra recording in 4K, what is the estimated storage size required per minute of recording?
4.) Does the Arlo Ultra (via the SmartHub), record in "video block" of say, 5 minute at a time, or does it record in one continuous segment?
Thanks for any feedback the community might offer!
steve_t
Master Master
Not sure about the rest but
2. 256GB max
st_shaw
Master Master
For 1) "We recommend that you use a microSD card with a minimum of 16 GB capacity, Speed Class 10, UHS1, V10."  Those are 10 Mbyte/second cards.
For 3) My Ultras have been using about 1.8 Mbits/sec in 4K mode per camera.
  • 2 Replies
  • 5930 Views
