Great news! Apple HomeKit is now supported on Arlo Ultra cameras!
For more information, take a look here: Apple HomeKit is now supported on Arlo Ultra cameras
HomeKit is now available for Pro and Pro 2 cameras, for more information on this and how to set up with HomeKit, take a look here: Apple HomeKit is now compatible with Arlo Pro and Pro 2 cameras!
HomeKit compatibility for Ultra is slated to be released in Q4. We will keep you updated as new information arrives.
Great!! How do we get the Homekit code?
Mine seems to be stuck at the "Discovering your device. Please wait." stage. Doesn't seem to ever get past this no matter how long I leave it. I went into Settings -> My Devices -> [Selected one of my hubs] -> HomeKit Set up.
Will this integration allow me to tell Siri to disable my system when it is in Geofencing mode? This doesn't work from Google Assistant when I am in Geofencing mode. This seems to be a limitation on the integration - it works when going from "Armed" to "Disarmed" and vice versa but as soon as I use "Geofencing" or any custom mode I can't disable the system. This makes the Google Assistant integration useless IMO. I'm hoping the same is not true of HomeKit.
How did you get it to work?
There is no Homekit button in my Arlo app. If I go to Homekit app and try to add Basestation it ask for Homekit code. There's no Homekit code on the box or on Basestation?
*edit: see here: https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-camera-to-Apple-HomeKit
A couple of weeks ago my basestation started showing up as a HomeKit device but as you say you can't pair to it outside of the Arlo app since there is no code.
Today I opened the Arlo app and it popped up and said something like HomeKit is now available for your hub and the next screen will ask you for permission to read your HomeKit data.
In the settings part of the Arlo app, you will get a new menu item called "HomeKit".
The devices had done a firmware update. Perhaps manually check for updates.
It doesnt work.. Like a lot of the Arlo "Features"
Sadly walking away kicking rocks, mumbling, and slowly getting to a boiling gut wrenching scream —— WHY DO THEY KEEP LYING TO US!!!!! All I need is a little Home kiiiiittttttt in my life........
I eventually got it to work by deleting everything, all base station, cameras and accounts. but them Home kit wont connect to the Home hub remotely.. Everything I have ever tried to set up with this product has failed.
The Home kit video is really bad when compared to the Arlo app, even in SD mode, and you dont get audio when outside of the home WiFi network and using the Home Hub functionality in the Apple TV, this is an Apple Homekit limitation I believe.
You also cant set up the recording etc in Home kit, but you can automate a light coming on if motion is detected. So sort of useful, but not really. For best results I have to set the Apple TV to "Never Sleep" and I had to set a static IP on the Apple TV, or when switching from internal network to external the Arlo would go offline for a while. (10 minutes or so) until it sorted itself out again.
I sort of got it to work.. in Arlo last that is around 50% of the time.. but I gave up on it.. I then bought the doorbell. If you want to experience pure incompetence.. get one of these, these dont work at all.. Just crashes the app across all iphone models iOS 12 and 13.. I haven't seen a released product in this condition before.. I'm not sure how they thought this was ready.. It's about alpha one testing state..
I have followed the instructions😤. I opened Arlo app, selected devices, smart hub, and there is no Home kit to be found. There is no home kit code to be found on the base station/quickstart guide. A complete mystery! I have searched through support, all I find is frustrated customers with the same problem and no feedback for them and or solutions.
The only way I got it to show up was to delete everything back to default, delete the app and start again.
Thanks for your reply, I have the base station show up in Home kit, (add accessory) but I have no 8 digit code.
You dont need the number if you set it up via this menu in the Aro App. The number and the QC code options just automate this if you have them. Once you get the menu the rest of the set up is quite easy and straightforward.
Yes, Its easier said than done. I have iPhone 11Pro, google WiFi router connected to my modem. I deleted the Arlo smart hub from the Arlo app. I made sure my phone's WiFi was connected to my modem (where the Arlo smart hub is connected). I reinstalled the smart hub on the Arlo app. (The Homekit setup became visible). I followed instructions reinstalling cameras. Apple HomeKit works but I have to have my phone on the modem WiFi connection. When naming the cameras for HomeKit and Siri, for starters, I couldn't see what I was typing and then I found that it wouldn't accept whatever I typed in. eg. Backyard Camera (it automatically tabs forward after typing camera). It only accepted the word after I backspaced to the end of the word. I took me ages of trial and error. I'd hate to be someone with less patience and time on my hands.
Accessing Local Storage
