Hello . I am having an issue with either my Arlo cameras or App. I have 4 Arlo ultra cameras with 2 base stations. When I go into the app and try to play the cameras through the app it just says “ connecting” and just keeps Spinning . Also it seems my cameras are not recording motion like they used to. They are just taking a picture. I unplugged the base stations and restarted my router as well no luck. Also uninstalled and reinstalled the app. I feel like I’m looking over something very simple. Thanks in advance .
Side note the cameras are working perfectly in HomeKit. Just not in the Arlo app.
ChadWes,
The symptoms you describe sound like there could be a connectivity issue. What does the signal strength icon show for these cameras?
Question for support, any other solutions?
Not seeing a place to drag cameras the app
Accessing Local Storage
