arlo ultra audio - icon under the name of the cam is disactivated on the app
Hi guys,
I can’t hear the audio of my arlo ultra cam.
The audio icon under the name of the cam is disactivated on the app and I don’t know how to activate it in order to hear the audio.
thanks
Ilo77,
Check your devices audio settings to make sure the speaker/mic are enabled.
If the audio icon on your live stream widget shows an X, this means the incoming audio is muted. Tap the icon and this should unmute.
Accessing Local Storage
