I have 3 Arlo Pro 2 with their Base Station. They work perfectly. Now I bought an Arlo Ultra, which does nothing or even is a pain.
When connected she only streams video, doesn’t take pics and doesn’t record. Not only manually but even automatically. That means that when I go to Mode Armed, I can’t change the settings: the Arlo Ultra is in Detect Motion and No Action and that’s all. I also have Push notifications enabled and I can’t deactivate that: the save button is greyed. That means that when I use Modality armed I receive constantly push notifications from Ultra alerting me that there was a motion, but if I check the library of course there are no recordings and if I watch the stream it is too late too see what triggered it. So it is completely useless. To avoid to be stalked by these messages I’m forced to deactivate the Ultra or i couldn’t use the other cams to perform surveillance. So WHAT CAN I DO WITH THAT CAMERA? NOTHING
I think I will sent back the Ultra cam to the seller: a surveillance cam that doesn’t record if there is motion has no interest as a surveillance cam.
While live steaming in 4k you can not manually record or take snapshots. You can if 4k is off, not sure why but it is the same on pro3
Have you tried on another device or the web page at my.arlo.com to see if you can set it to your pro2 settings there. Your Ultra should be on the free premier trial for smart and cloud recordings.
Have you tried resetting the cam by taking the battery out and back in or removing it in device setting and adding it again.
Accessing Local Storage
