I just bought the 4 camera system from best buy. First time with arlo. I have my modem and router in my living room and hooked up the smart hub there. I put it about 8' away from my wireless router. My house is about 3,000sqft. I can not get any of my cameras to connect once i go outside my house? Is there a way to extend my signal?
Chris
There is no way to extend your Smarthub's signal.... The hub sets up it;s own wifi network for the cameras only.
You can 1) locate the hub centrally so all cameras get a signal ( you can use a wifi extender with an ethernet port or cat5 cable if there ) 2) buy a second hub so that all the cameras get a good signal ( one at each end of home ) as this is the only true way to expand coverage area
Yes, the bases need internet access via ethernet port, but they don't need to all be on the same network.
you can have multi bases in multi locations ( even diff states ).
They will work on extenders with ethernet port if the extenders reach.
Accessing Local Storage
