My backdoor camera just started recording everything in purple. I checked the wi-fi and it is very good. I tried resetting it but is still records or shows a purple video in any mode.
This usually means the nightvision IR filter is stuck.
Have you tried turning removing the battery for a few minutes and then reinserting it?
Is the camera still under warranty?
Its not under warranty, I checked, I'll try the battery like you stated.
Shaking the camera a bit might also release it. Some folks have had success releasing the filter in older cameras with a magnet - somewhere buried in the forum there is a photo showing that.
The battery trick worked! Thank you!
Accessing Local Storage
