  • 4 Replies
  • 1058 Views
t82inker
My backdoor camera just started recording everything in purple.  I checked the wi-fi and it is very good.  I tried resetting it but is still records or shows a purple video in any mode.
This usually means the nightvision IR filter is stuck.
Have you tried turning removing the battery for a few minutes and then reinserting it?
Is the camera still under warranty?
t82inker
Its not under warranty, I checked,   I'll try the battery like you stated.
Shaking the camera a bit might also release it.  Some folks have had success releasing the filter in older cameras with a magnet - somewhere buried in the forum there is a photo showing that.
t82inker
The battery trick worked!  Thank you!
  • 4 Replies
  • 1059 Views
