VMB5000r4 not recording to SD card - again. Tried reformatting and rebooting/resetting.
My VMB5000 stopped recording to SD card again. Firmware 1.16.6.2_1022_c366487
Tried to reformat the card in PC or in the hub with no result. Rebooted, reset, etc.
SD card recording is on. Tried changing other options - nothing.
Not good - especially after all adventures with SD recording.
Before you buy - you need to know that this system does not work and has nothing to do with security or professional device despite "professional" price.
Are you making sure that you're formatting the SD card in the FAT32 file format in Windows?
Also, try a different SD card.
Couldn't have said it better myself, Arlo is an absolute garbage product
Accessing Local Storage
