Arlo Ulta 4 base station(s) reboots VERY OFTEN...not reliable in my experience to date.
I have a large home with sixteen Ulta 4K Cameras and four base stations (each with four Ultra 4K Cameras assigned), each is plugged directly into the NetGear Mesh Network Base station router or one of the three Satellite routers.
Has been a Very High-speed reliable network with 1GB Internet connection, so I don't the issue is the network or Internet access speed.
Not sure if all the base stations or Cameras are stepping on each other or what.
Hi Kdes, how do you know the base stations are rebooting?
thanks,
Jonathan
Because I can see the light go from Blue to Yellow, wait and then eventually go Blue again and then the Image comes back...Just like when it is first powered on, hence why I say reboot.
Do you have any ideas?
Hi kdesforges,
When you say the light goes from blue to amber and then goes back to blue, are you saying that it shows a solid amber LED, slow blinking amber, or an alternating blue and amber?
Accessing Local Storage
