Definitely update to the new FIRMWARE! pretty much all base station models got the update! It fixed so many issues. If its not updated get in contact with Arlo support they can have it updated!!! I know everyone is frustrated with Arlo but I have been running beta firmwares with the Engineers at Arlo and they have fixed a lot of bugs! Please comment and tell me if the update helped you guys
What would be that firmware number because mine says no updates available.
Not sure but I believe he means 6cd3d19 that was updated on the 10th.
must be because it's not likely to be another so soon.
Follow these steps to check the firmware available and to check what you have.
- On this forum go to Firmware Release Notes to see the latest update number available
- To check your version go to My DevicesArlo > SmartHub > SettingsDevice Info > Firmware
- On my VMB5000 I have 1.16.3.2_693_6cd3d19 which is the current version.
Accessing Local Storage
