Our trial subscription ended a month ago and I am loathed to pay for it as this has been happening so often (at least once a month when I notice).
I have geofencing set up and also this doesn’t work when I add my husbands phone - location service on his phone are set to always.
This is super frustrating and the thousand odd dollars spent on the three cameras feel wasted as if I’m not checking constantly I’m not confident the cameras are operating.
Hi @Julmo
May I ask which troubleshooting steps you have performed so far, regarding the lack of recordings? I don't want to suggest any prior methods you have previously performed.
With geofencing I have tried removing my husbands phone, putting it back on, updating his app, checking location services for Arlo is set to always on.
I’m on an iPhone 12, his is a Huawei p30.
It is yet another issue with this poor system. If I hadn’t spent so much in purchasing it I would have ditched it a long time ago.
Hi @Jsijnja
Please try & reboot your camera by removing > Inserting the battery. If you like you can also try to remove the camera from Settings > My Devices > Re-Add it.
Thanks, I will try that. I worry though that this will happen one time when I’m away from home and relying on the system to be reliable and not need manual intervention. Is there a way I can disable firmware updates for periods when I’m away so I can have confidence a firmware update won’t cause these kind of issues?
Thanks,
Jacob
(Note that I only have the IPhone on for location services as it just didn’t work when my husbands phone was also on there).
Does this issue still occur with the latest v3.2 of the Arlo app?
Went to husbands phone this morning and activated geofencing and his phone.
Have left home.
Am now getting pinged constantly as he is moving round the house.
It’s it so bloody annoying. So now I’ll have to turn it off for the day and hope that I remember to turn it back on when we all go out.
Would be better if it just worked properly.
Is the latest version of iOS 14.4.2 installed on the phones?
Mine definitely has the latest.
I’m pretty sure his has the latest software.
Yesterday I removed him from the access rights.
Then set up two step verification (which I don’t think he had - every time I logged in it came up saying to enable it even though I had it - so I wonder if it was doing that because he didn’t).
Re-added him.
Then when we were both out I turned on geofencing.
Now we just have to wait until tomorrow when he is home and I am out.
Asked husband and he says his phone has latest software.
I have left home while he is there and I am again getting constant notifications as he moves round the house.
Yesterday’s attempt to fix didn’t work.
Expecting my mother to arrive any minute.
Checked cameras on my pic.
It says base station is offline.
Log back in to the app and says armed.
Log back in using the app and all cameras working fine.
This is such a cr**py system.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
I didn’t contact support sooner as I hadn’t thought about getting some help until we got the reminder about the trial ending - which prompted me to do something about it - but now I can’t without paying.
Should have done something sooner but life got in the way.
I believe you can still engage with support w/o being charged.
Accessing Local Storage
