Just upgraded my system from Pro 2 to the Ultra over the weekend. I’ve had the Arlo Door Bell installed on the Pro 2 system since the door bell was launched. It worked fine.
However, I have not been able to connect the door bell (or chime) to the SmartHub. I tried everything numerous times. Rebooting the hub, resetting the hub, holding the door bell sync button for 10-secs, etc. No luck.
Called Arlo tech support the other day and they told me the door bell was not yet compatible with the SmartHub. They didn’t even offer my any assistance for trouble shooting.
Curious...why I couldn’t find any other posts on either the Ultra or Door Bell threads? Anyone have similar issues? Anyone else been told by Tech Support that the door bell is not compatible? Anyone got the door bell connected to the new hub?
Thanks...
Note: Using SmartHub Model VMB5000 not the VCM4030P as shown on the posting. Drop down box doesn’t give the VMB5000 option.
LinoS,
Sorry, I posted the wrong link, try again it should now be updated. 1.12.1.6_32471 is the current SmartHub firmware version.
Was your doorbell synced previously to a different base station? If so, yo might need to reset the doorbell with these instructions: How do I reset my Arlo Audio Doorbell?
Hey my app is also not finding the Arlo Doorbell that came with the new Ultra kit only last week. All firmware is up to date according to previous reply. This is really frustrating...why give away a companion products that dont talk to each other!
They do talk to each other for some (most?) people so it isn't a case of the system being totally broke, just your combination.
There is, therefore, hope.
The firmware that allows this feature to work is new, it might be worth resetting everything back to factory defaults and trying again.
Does that mean that you have looked at the firmware on your devices and checked them against current?
Just another user
@mrhilly wrote:
Which is why after 10 days usage I packed it all. Doorbell + ultra now returned and fully refunded.
Just in time to miss the update that fixed it for many people this weekend?
Just another user
I also don’t understand why the firmware update works of some and not others?
I’m very happy with everything else...just wish I could get the doorbell working!
That's always the puzzle. If it was bust for everyone it would be easier to finger the defect.
Just another user
@53Crusher wrote:
There is another phone app update today, maybe that will help those who are still having problems connecting their doorbell?
Good catch. Firmware and apps go hand in hand.
After all, you can't even "onboard" the doorbell through the browser graphical user interface.
My Android app just updated from 2.7.3_25566 to 2.7.4_25567
Just another user
@antcraw wrote:
Yes , I can confirm that firmware is up to date. I have attempted reset on the doorbell by holding down the sync button for 10sec with batteries...the led does not flash for me.
I find that I have to hold the reset button for >10 seconds, maybe 2 or 3 seconds more. Keep holding it down.
antcraw,
I will reach out to you in a private message to gather more information on this issue.
When the update will be released? I purchased the doorbell one month before the ultra system came out. Now I have a doorbell and a chime for decoration because it doesn't work with my ultra system, and I can't return it to the store because it has more than 30 days. Please give me a solution.
Julio
@53Crusher wrote:
Updates were released on 3/23. That's when my doorbell and chime started working.
In case you missed it, also check for updates for the Android/iBeast) App that you use.
Firmware and apps work together.
Just another user
Is anyone still experiencing this issue after making sure they've updated their app to the latest version?
Accessing Local Storage
