Ultra PVR Plan Problem
Today i upgraded to ultra, got my free 1 year plan but dont have the option to add PVR 4k recording unless i upgrade to the elite from premier plan. is this right?
No, that is not correct. You should be able to get it with the Premier plan also. I don't remember exactly the steps to get the PVR plan, but you might have to select your subscription then go to change plan to add it. You should not lose your free plan if you add PVR or don't make any changes.
Brian
Well, it could be done as I still have the "free" plan for the first year and have my four cameras signed up for the additional PVR service (frustrating that we have to pay extra to get the functionality that we bought the system for but I guess we should have read the fine print first). It seems there are a lot of changes going on right now with Arlo may just need to give it a day or two and try again. Sorry wasn't more help but maybe someone from Arlo will chime in...
In the for what it's worth catagory I'd love to hear your personal opinion on video quality between the Pro2'S and the ultras.
I also have the same problem of my recently bought Arlo ultra. I can't seem to upgrade to PVR on my free premium subscription. Did you find any solution?
Where are you? And where did you buy?
I ask because of this:
Solved: Re: Arlo Ultra - Smart Plan - Arlo Communities
The free 1 year plan is only claimable in the country in which the system was purchased.
Just another user
Hi,
It was bought and are being used in Sweden. The 1 year free plan is working, but there are no ways to add PVR to the subscription.
If I change subscription to Premium Elite, I can choose which cameras to add PVR to. I don't need Premium Elite nor want to pay for it since I have 1 year free premium.
Ewestin,
To add PVR, log in to your Arlo account from a computer and navigate to Settings > Subscription > Change Plan. Now simply click continue (making no changes to the account level subscription) and you should be presented with options for the PVR add-on.
Accessing Local Storage
