Ultra Manual record feature not working
  • 12 Replies
  • 3493 Views
James1012018
I can’t push on my record icon can you help
12 REPLIES 12
Need more info...
Phone / OS/ what does work / etc
Also have you tested same on browser at MY.ARLO.COM
James1012018
It’s an iPhone.. can’t see live video on my phone and it does not record any video light does come on when motion is detected but no recordings yes I have gone to the web site
James1012018
All the settings are on record icon is back and turned on but still no recordings
ShayneS
After manually recording on the Arlo mobile app/web browser, are the recordings missing on the mobile app and web browser?
James1012018
I can’t manually record anything is doesn’t work have resets every camera and base station and still one camera won’t work
James1012018
Sorry it is recording to base station but only for not even a second
James1012018
This is a picture has a different symbol on it
ShayneS
Sorry for the repetitive question, Does this behave the same over the mobile app and web browser?
James1012018
It’s does not record on the mobile app but does record to web browsers but only for a second
ShayneS
Does the manual record work on a different web browser?
James1012018
ShayneS
Hi @James1012018
Can you login to your My Arlo account and navigate to > Settings > Subscription > Manage Cameras And add your affected Ultra camera to your Add on plan. It looks like that camera is not currently assigned to your Smart Plan.
Also can you test the other cameras to see if the manual record feature is functioning properly, and make sure you have Library filters cleared.
Thanks!
  • 12 Replies
  • 3494 Views
