Ultra Camer has no notification
I stopped receiving my push/email notifications from the ultra camera. The initial installation was ok for a week or so, notifications operated normally for the Ultra camera. I have a Pro 2 camera connected to the same hub and is operating as advertised. I tried removing, reinstalling the devices. on both moble and web applications. Moble app has been removed and reinstalled. Base station has been reset. Router as been cycled. The settings for notifications are correct in the phone and the arlo configuration. I would expect the Smart hub to be in control of the notifications but I may be mistaken. Any input would be appreciated.
brrish,
Are you using a custom mode or the default "Armed" mode? Do you also have e-mail notifications enabled? Do you receive those without issue?
I was using the Arm mode for testing last night. I use the geofencing to arm/disarm the cameras. No custom cross triggering or schedules. I do have email enabled on both cameras but only receive push and email from the P2.
brrish,
Try creating a custom mode with just rules for the camera in question (without utilizing geofencing) as a test and see if you experience the same behavior.
Also, take a look at the Smart notification settings for that camera and be sure the appropriate toggles are selected.
I am operating without a smart plan. I accidently canceled the "free 1 year" plan not realizing it was free. The off shore customer support said there was nothing they could do. I can not take the step you want me too. I have tried just arming manually and testing, no change. I think that satifies your first suggestion.
After revisiting the APP and rethinking your suggestions it looks like I can not do either. No custom options without giving up $100 for a plan on a system I am not so sure about keeping. My only options are a schedule, armed, disarmed, or geo.
I have done further troubleshooting and it seems when the P2 camera is set to push notifications it shuts down the ultra push function, not immediately but withing a short period does. Turn the push off on the P2 and the ultra starts pushing. And just to be clear both cameras are connected to the Ultra Smarthub. Any further input would be appreciated.
brrish,
To receive notifications/recordings for Ultra, you must have a subscription. If you canceled the included free 1 year subscription, this would result in the symptoms you describe.
I will reach out to you in a private message to gather more details.
Accessing Local Storage
