Looking at upgrading my Pro's .
How is the battery life on the Ultra? I get 4-6 months on my Alo Pro
Like all Arlo wireless cameras, it depends on lots of things. The fact that you get 4-6 months from a Pro means you should get similar results from the Ultra. Of course, the wider angle view may catch more motion and create more recordings which can be much larger (4k). That consumes battery so it could be worse. Carefully positioning the camera, adjusting the viewing angle (180, 155, 0r 120 degrees), etc, may be needed.
You wont get 4-6 months from an Ultra battery unless you have the camera turned off. Its anyones guess honestly, but you should expect it to be significantly worse than Pro battery life.
Accessing Local Storage
