Says it needs firmware update - new from box
but it won’t update
tried lots of times
ideas please
In the end I deleted camera then re installed
only took me an hour 🙄
Jeffonhols,
Did the camera resync allow you to download the firmware update? Are you still experiencing issues?
Yes the resync did update the firmware
and it’s working fine
but
I’m using one cam in my shed which has a WiFi extender in there but it’s struggling to find the weak WiFi signal 🙄
Jeffonhols,
Arlo Ultra cameras connect directly to the SmartHub. Your WiFi extender will not have any impact on the signal strength of your cameras. If your camera is struggling to maintain it's connection with the SmartHub, you may need to relocate the camera or move the SmartHub closer to it's location to improve the signal strength.
Thanks James I didn’t realise the location of the hub was the key issue .
whats the maximum range of signal from the hub ? Approximately .
i realise that building structures will affect this.
Jeffonhols,
This article might help, take a look here: https://kb.arlo.com/35/How-far-can-I-place-my-Arlo-wire-free-cameras-from-the-base-station
Accessing Local Storage
