Trying to view footage on calendar from 2 weeks ago
  • 1 Reply
  • 248 Views
Tommo1
Trying to view footage from 10-14 days ago unable to view in calendar it will not alight to see it ?
This is with an Ultra?
Do you see "Feed" and "Dashboard" in your app menu?  Or do you instead see "Library"?
Are you using my.arlo.com, or are you using the app?
If you see "Feed": Are you saying that the calendar dates aren't showing up blue with a dot under them?
  • 1 Reply
  • 249 Views
