Too many Audio alerts - how do I reduce the audio sensitivity?
  • 4 Replies
  • 2488 Views
Reese5588
Hi
I am getting a lot of notification from sound it has been fine, it drians battery very quickly, how can i reduce the sound volume so i dont get less notification, i have turn on noise reduction, or is there any other problems
If you edit the camera rule in the mode, you will see there is an option to reduce the threshold (requiring more sound to trigger the audio alert).
Reese5588
which way do i go towards the 1 or towards the 5?
Reese5588,
The smaller number represents less sensitivity. So if you want to reduce sensitivity, reduce the number on the slider.
Reese5588
I tried that, but went its very windy it still does it so i have turned it off.
  • 4 Replies
  • 2489 Views
