Has anyone had any luck with these?
In principle, a solar panel combined with a storage battery will work. If you use a USB power bank for the battery, note that some of them will shut off if the current used is too low, potentially causing problems using them for Arlo.
I have a V88 from Voltaic that works with the Pro2. I haven't tried it with the Ultra though. When plugged into the V88 battery, a Pro 2 thinks it's on AC power, so activity zones and CVR can be enabled. The V88 pack is 88 Watt-hrs. I don't know if that's enough to sustain CVR 24/7, but the V88 powered a Pro2 with activity zones and 3-second look-back and used about 25% of the battery in 24 hours.
The V88 battery includes a built-in MPPT solar charge controller, so you can plug a solar panel into it while using the battery to keep it charged up.
Accessing Local Storage
