Recordings triggered via IFTTT are often truncated when the camera is not on power
I have an Arlo ultra camera and smarthub which I am using for a timelapse capture of a home remodel.
When connected to power, the camera gathers recordings faithfully, at the time configured, at the duration configured in IFTTT.
However, when I have the camera disconnected from power, at least 1/2 of the recordings are truncated. It's configured to record for 60 seconds. Some of the recordings might be only a few seconds while others are 10s of seconds.
I assume this has something to do with the latency to wake the device when on low power. Does anybody have a suggestion?
Dig,
This could be a connectivity issue, what does the signal strength show for this camera? How far is it from the SmartHub?
Signal strength shows strong.
It's only about 2 feet further from the SmartHub at its new, unpowered location. 4k video streaming is strong.
I just grabbed a 20', weatherproof power cable. I'll try to A/B the power versus no power at the same location.
Confirmed.
I got a long power cable delivered.
The camera has run for 12 hours on power, in the same location, on the same smarthub without missing a beat recording.
On battery, maybe 1 in 10 recordings was the full 60 seconds with most being under 10 seconds.
Accessing Local Storage
