Hi All
Just noticed a bit of different behaviour on my Arlo app recently, and certainly since the updates (Arlo app on Android and firmware update on the base station), but I'm unsure if it's related to the app or firmware, as both (rather unwisely) happened around the same time.
I can't always replicate it, so unsure what's causing it. However the following has happened on a few occasions now:
- battery status, signal strength, motion detection icons are all inactive, but the local storage access one is active
- audio doorbell and its chime show a red exclamation mark
However, choosing 'live feed' and 'local storage' still work.
The other thing is that when I switch off an Ultra camera on the app, it shows as 'on' on the web browser. So, the big question is: is it on or off, or both?
Thanks, I was able to replicate the "The other thing is that when I switch off an Ultra camera on the app, it shows as 'on' on the web browser. So, the big question is: is it on or off, or both?" issue. I will let the Dev team know and update the thread as soon as I can.
It's all over the place, hope it gets sorted
Same, yet again Arlo has broken the access to local storage. 2nd time in less than 6 months. Good regression testing by their team.
It's also strange because our front door camera runs off electrics, whereas when this unresponsiveness happens, it shows as if it was running off the battery.
This kind of behaviour started following the last Android and base station firmware update, so it's defo related to that.
@Le22
Can you provide more detail regarding the issue you are experiencing.
@Le22
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Yes , have same problems and some. 2 of 5 AC powered cams showing as running on battery , sometimes no icons as the screenshot the other complainant posted and most recently hub flashing orange yet everything works (ie recordings etc) however one cam I have AC powered has dropped to 10v and has remained showing that for 3 -4 weeks but it still works although it shows as AC and charging it wont go above 11v ......Since the orange light on hub flashing it refuses to be restarted but have tried unplugging it etc .
Hi Shane , did you see my reply ?
@Barney999
Sure did, a member of the L3 team will be reaching out to you regarding your issue(s).
An email has been sent from Jeff on the L3 team, he is requesting a zoom call for 12pm PST today if possible.
Accessing Local Storage
