Problem charging batteries for Arlo Ultra 2 cameras (VMC5040)
I have 3 Arlo Ultra 2 cams and an Arlo dual charging station. When I charge battery #1, the charging status light eventually turns green. When I insert this battery into a cam the cam’s blue light blinks and the cam operates ok.
But when I charge battery #2 the status light remains amber and blinks; and when I charge battery #3 the status light remains amber and doesn't blink. When I insert battery #2 or battery #3 into a cam, the cam’s blue light does not blink and the cam does not operate.
Are battery #2 and battery #3 useless now?
Sounds like they need to be replaced.
If you go ahead with that, you might also consider upgrading them to XL while you are at it.
Accessing Local Storage
