Poor sound on brand new Ultra system
Just installed a new Ultra 3 cam pack ( VMS5340-100AUS ) in my personal residence as a product evaluation test
( before I consider installing them in my clients houses)
System and camera did all the suggested update etc....
on a hole all working well
How ever spending $1500 RRP on a system and the sound quality is 100% un usable / in-audible
I purchased the system with the belief I could atleast communicate with the person in the camera shot
absolutely impossible to do this currently.
I have ensured all setting etc are up to max and tried every possible variant of wind reduction etc.
Looks like these will be getting returned and recommending all my future clients to avoid this product.
Disappointed just is a good enough description
Sirbreaksalot,
Do all of the cameras behave the same way? Have you tried testing in different locations to further isolate the issue?
From my experience it's as if the speakers are not sufficient.....the microphones work perfectly..... it's the output sound lack of quality... it's just a crackly distorted noise ..... if this is the quality... I 100% won't even bother trying the video door bell.
Sirbreaksalot,
From your description, this doesn't sound like typical behavior. I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
It's not a ph issue... as 3 phone do the same.... 1. The speaker in the camera is inadequate 2. Software needs to increase mix volume from phones to app ..
You are not going to make any friends installing this in a clients house. This system is not ready for prime time. Every time they release an update they break something. Unless you like having unhappy clients you should look for another product!
Don't use the verbage " crystal clear 2 way audio." Cause it ain't by a long shot
Accessing Local Storage
