I’ve started using a 2 camera Ultra system today and one cameras motion detection will not work. I work in IT so did all the usual stuff turn hub off & on, remove batteries, remove device
and re-installed and it will not work. I’ve created a test mode for the dodgy camera and still doesn’t work. It works when using live but that’s not much use if the motion detection does not work. It’s just the one camera, the other works fine and the camera settings seem to be the same. I’ll be asking for a refund unless this is resolved.
Also, does your home router have its default security settings? Who is your internet service provider?
What modes have you used? The Armed mode should always work.
You can always swap at the store before getting a refund.
Hi Andy, do you have an active subscription for that new camera? That is usually the reason an Arlo camera won't record/
If so click on edit mode and make sure you have two rules set up (one for each camera). Compare each rule and take a good look at the rule for the camera that is working. Then go to the camera that isn’t recording rule and make sure no settings are missing.
Also delete the other test mode you made and ensure just using ’armed’.
Did the recording job used to work for that second camera or never did?
The camera didn’t detect motion when it was unpacked and in the same room as the smart hub
Accessing Local Storage
