My camera spot light stays on and drains the battery
Have you tried anything to fix it?
Two possibilities:
- Remove the battery and reinsert it (rebooting the camera)
- Do a factory reset. Remove the camera from the account. Open the housing and press the sync button inside until the camera LED flashes amber (~15 sec). Then add the camera back to the account.
Two possibilities:
Thank you StephanB, your advice worked.
