  • 2 Replies
  • 464 Views
Mikey86
My camera spot light stays on and drains the battery
Have you tried anything to fix it?
Two possibilities:
  1. Remove the battery and reinsert it (rebooting the camera)
  2. Do a factory reset.  Remove the camera from the account.  Open the housing and press the sync button inside until the camera LED flashes amber (~15 sec).  Then add the camera back to the account.
Two possibilities:
Mikey86
Thank you StephanB, your advice worked.
  • 2 Replies
  • 465 Views
