I've noticed that the MP4 files downloaded from my Ultra cameras are missing the "Encoded Date" and "Tagged Date" in their metadata. This is pretty surprising and annoying considering this is a pretty important bit of metadata for potential legal issues. And also for sorting the files locally, if downloaded in batch.
In contrast to the Ultra, I've checked the metadata on MP4 files from my ArloBaby cameras, and those do have
the "Encoded Date" and "Tagged Date" metadata.
SEE BELOW for two full MediaInfo examples.
So what is it about the Ultra cameras that causes the files to have missing Encoded Date metadata?
And is there any way to fix this?
thanks.
FROM ALRO ULTRA
General
Complete name : 1574065006549.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 1.62 MiB
Duration : 17s 416ms
Overall bit rate : 780 Kbps
Writing application : Lavf58.20.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 721 Kbps
Width : 1 920 pixels
Height : 1 088 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 14.470 fps
Minimum frame rate : 3.413 fps
Maximum frame rate : 15.152 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.024
Stream size : 1.50 MiB (92%)
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 17s 409ms
Bit rate mode : Constant
Bit rate : 56.0 Kbps
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 16.0 KHz
Frame rate : 15.625 fps (1024 SPF)
Compression mode : Lossy
Stream size : 119 KiB (7%)
Default : Yes
Alternate group : 1
FROM - ARLO BABY54
General
Complete name : 6YTHBUNP-300-7339691_4WD174SU3B7DD.mp4
Format : MPEG-4
File size : 4.65 MiB
Duration : 21s 120ms
Overall bit rate mode : Variable
Overall bit rate : 1 849 Kbps
Encoded date : UTC 2019-11-28 15:32:19
Tagged date : UTC 2019-11-28 15:32:19
Video
Format : AVC
Format profile : Main@L4.1
Format settings, GOP : M=1, N=39
Codec ID : avc1
Duration : 21s 0ms
Bit rate mode : Variable
Bit rate : 1 825 Kbps
Maximum bit rate : 3 000 Kbps
Height : 1 080 pixels
Frame rate mode : Constant
Frame rate : 10.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.088
Stream size : 4.57 MiB (98%)
Title : WowzaStreamingEngine
Language : English
Color range : Full
Audio
Format : AAC LC
Bit rate : 31.1 Kbps
Channel layout : C
Stream size : 80.2 KiB (2%)
Language : English
Default : Yes
Alternate group : 1
Looking all the way back, even into the Ultra beta, I don't find any date/time embedded in any of the Ultra videos so it appears that it was never stored for whatever reason. Note that the filename, depending on the platform used to download the video, has the epoch time as (part of) the filename.
thanks for the confirmation. its good to know this issue is not just something with my configuration.
i still find it really weird that these MP4 files don't have this metadata embedded, and we
also don't have an option to burn in a timestamp on the video itself.
these are security cameras right? 😕
Accessing Local Storage
