Library function entered activates cameras
- Why when I activate the library function, does it activate all cameras to on?
- corporate ability to be noticed and view capability?
- if I want to view or delete … the cameras are activated for about 2-3 minutes after close ?
1) No. That's up to your active mode and the rules inside that mode.
2) "Corporate ability"? What do you mean? If you're looking for the ability for others to be able to see the cameras and recordings, check Settings, People and click on the "+" at the top right to send invitations to the others' email addresses.
3) Live view continues for as long as you're using the same view where you started that viewing. Changing to a different tab/page stops the viewing. There's a 30 minute timeout on live viewing to preserve the battery. Not sure by what you mean by "delete".
Accessing Local Storage
