I am unable to view my recordings locally
- Since the new app, I am unable to view my recordings locally. I have a Smart Hub HMB5000 so I shouldn't need an SD card right? What am I doing wrong? Please help.
Message 1 of 3
250
Best answers
@Aminazzfamily wrote: I have a Smart Hub HMB5000 so I shouldn't need an SD card right?The VMB5000 has no built-in storage, so you do need to add a microSD card to it. The slot is underneath, so easy to miss.
I suggest getting a card in the range of 128-512 GB. Anything larger is overkill (and a lot of large c
Message 2 of 3
248
Hi, You likely do need a microSD card. (VMB5000) Smart Hub requires a microSD card for local storage, as it does not have the internal storage or USB port that some older or larger hubs have.
Message 3 of 3
127
Accessing Local Storage
