  • 5 Replies
  • 680 Views
BoMagnus
With the new app interface, I can't deactivate one or more cameras in surveillance mode.
On windy days or other occasions, I need to deactivate some of them.
How to do it in the easiest way possible?
5 REPLIES 5
Go to devices, and press the settings wheel.  Then disable the camera there.
Kanelbulle
Ok I disable the camera, but…Why does the camera enable automatically?
It won't enable automatically after you disable it from the camera settings wheel.
It can be re-enabled from the devices screen (or widget) if you press "enable device" in the center of the video tile.
BoMagnus
It does. Why do you think I ask this question?
Are you disabling them from the camera settings wheel?  After that, are you seeing "enable device" in the video tile?
Or are you changing the mode using the dashboard?
What cameras do you have (first post says Essentials, but the forum area is Ultra)
Are you using a base?  Or are the cameras connected to your wifi?
Are you using custom modes, or the three built in ones?
Do you have a schedule set up for the cameras?
Do you have geofencing set up>
  • 5 Replies
  • 681 Views
