How remove micro sd card from bastation
Hi any have the same problem that me i Cant remove the microsd from basestation ?? Or Im doing something wrong?
It is "spring loaded". A gentle push should release it.
The manual explains what to do.
Arlo - Security Cameras and Systems
Just another user
I suppose that will do remove the card but when i push the card dont go back
@CARLOS1Pr wrote:
... when i push the card dont go back
Push it back in again.
Just another user
Accessing Local Storage
