Ultra emitting random distortion sounds and high pitched beeping
Product: Arlo Ultra
Firmware: 1.070.50.2_205_0c7c8e1
Base: VMB5000r4
Firmware: 1.15.0.4_297_aa40f04
About two weeks ago we noticed our Arlo Ultra emitting distortion sounds while being outdoors and close by. We brought it inside and the sounds, distortion or high pitched beeping has been randomly happening perhaps five or six times since. It’s irregular and does not follow a pattern but we managed to accidentally provoke a distortion sound while it was on the bookshelf and got triggered by swiping a hand in front of it. When it stopped (after maybe 20 seconds) a second attempt to trigger it directly afterwards instead made the camera go into a high pitched beeping (see link below). Several following attempts were however unsuccessful.
We’ve looked for new firmware and can’t find any updates for either base nor camera. We’ve removed the battery and let the camera sit over night, and the same noises has been happening.
Our system additionally has two Pro 2 cameras, a doorbell and chime, all working without a hitch.
Anyone experiences similar issues and have advice on how to fix?
This sounds like a hardware issue to me - I suggest contacting support. https://www.arlo.com/en-us/support/contact.aspx
@Arloultra wrote:
Have you tried to re-sync the camera to the hub?
You could try pulling the battery and reinserting it (which would reboot the camera). Then perhaps resync.
If that fails, I'd just contact support.
Accessing Local Storage
