I suggest to develop the technical ability for the Arlo App to access the SD card recordings of and on the Arlo Hub. I am recording video locally and saving it on the micro SD card in the Hub. If I want to view videos, I have to take the SD card out of the Hub and put it into the card slot of my computer. This is rather cumbersome. I would appreciate if I could access the recordings directly on the SD card while still plugged into the Hub (without the need to unplug and shift the card to the computer), via the e.g. mobile App (similar to how I access cloud recordings).
Thanks for considering.
They implemented this a few weeks ago. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Accessing Local Storage
