  • 4521 Views
  • 2 Likes
rosannd07
I installed my Arlo Ultra last night outside.  I don't want the floodlight to be constantly on.  Is there a way to control the settings so the floodlight only comes on when there is movement and then turns off after a period of time?
michaelkenward
Sensei Sensei
Sensei
Is it always on? It shouldn't be.
The light on the Ultra is tied to its recording. If you set a rule to record when there is m,ovement, the light will come on at the same time.
Unlike the Pro 3 Floodlight, you cannot control the light independently.
Just another user
michaelkenward
Sensei Sensei
Sensei
Just another user
HazzMatt
It's true that the Ultra floodlight is tied to motion. I don't want the floodlight on some of my cameras at all. You can turn the floodlight off in the camera settings; Device Settings, Video Settings, Low Light Settings, then toggle Spotlight On or Off.
rosannd07
Thank you - that appears to have worked.
Rosann
  • 4522 Views
  • 2 Likes
