Cwmmmm,
At what point are you experiencing an issue? Can you provide more details?
Are you following the instructions listed here when setting up each feature?
What is Direct Storage Access and how do I use it?
How do I connect my Arlo camera to Apple HomeKit?
Cwmmmm,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I have the same error message for direct storage. Same cameras and also iOS. Same error on both iPhone and iPad Pro.
Tried reformatting the SD but it’s still not working.
If you haven't fixed this yet, I had same problem until I enabled port forwarding on my router and input the IP address of hub and specified ports.
@jpmanciniii wrote:
How did you do this
Details depend on your router. What is the router's manufacturer/model?
I'm having the same issue. When I go to Arlo homekit setup I get the connection circle and it's just looking for my devices but it can't find it so no connection at all.
Accessing Local Storage
