  • 1 Reply
  • 1158 Views
  • 1 In Conversation
DLBABQ
I have an Arlo Ultra 4 camera setup. It works properly until I insert a FAT32-formatted micro SD card into the hub. As soon as I do that the hub goes offline and I get a flashing amber light. The card is a 256GB Lexar Professional class 10 UHS-II V60 card. Telephone support has been unable to explain the behavior, so I'm putting it out to the forum. Thanks in advance for your help.
DLBABQ
Problem solved. Had to do a factory reset on the SmartHub. But then I lost all of the cameras connected to the hub, and I was unable to reconnect them using the Arlo app. To get everything to work properly I had to press and hold the sync button on the Hub and each camera for 2 seconds. I then went back to the app and added the cameras as usual. More of a pain than I was hoping for, but everything is now working properly.
DLBABQ
  • 1 Reply
  • 1159 Views
  • 1 In Conversation
