Cut magnetic charger cable to pass through wall?
I just bought 2 Ultra 2 cams and I want them plugged in so I don’t have to charge batteries. The USB end and the magnetic charger end are both 1/2” wide but thin. That’s an awfully big hole to make for a skinny wire.
Can I cut the charger wire in half so I can just pass the skinny wire through the wall instead of trying to pass the entire USB head through the wall then splice it back together once it’s through the wall?
It's certainly possible, but not something Arlo recommends.
It looks like your best option though - certainly better than a 1/2 hole.
I'm in the same boat as you are, feel bad to put such large hole for just that small size of a cable.
If you did cut it, was it just a simple 2 wire or was there any wire shielding too?
Thank you
When there is a power source available (everybody's situation is different) what I did was add a outdoor receptacle to my front and back porch lights along with my deck light and am able to plug in all six of my cams.
I guess I'll just cut the cord and see for myself.
I'll post a picture once I cut it so if others ask the same question they will see and have an answer too.
Hi MMM-PR ,
I am curious about these outdoor cable. I try to search for the drawing but could not find. I am interest to know:
- Overall cable diameter.
- Number of conductor inside the insulator.
- What gauge.
- For 25ft cable, do they required a different charger adapter? Due to power drop through the long cable (assumed as someone said 9V charge, not sure how many Amp)
FWIW, the 25 ft cable has an integrated charger (which is of course one reason why you might need to cut the cable).
Did you end up cutting the cable? I need to do the same. Thanks
Accessing Local Storage
