Cloud option in Library there one day gone the next
In the first week of having my Ultra SmartHub and camera's I used to be able to navigate to Library and choose 'Cloud' at the top. Now, I no longer have that option - the cloud selection is gone.
Since a particular point in time (unknown but suspect since sd card was inserted enabled then disabled) , it appears that:
- the recordings are correctly being saved to Cloud (took sd card out and videos still record).
- I can 'favourite' and delete any of those recordings via Library
But I just can't see any of cloud recordings that I use to be able to see. I don't understand. Any help would be appreciated.
I have tried:
- Rebooting Base
- Removing and adding back all devices
Firmware: 1.16.3.4_744_c289687
Hardware: HardwareVMB5000r4
SOLVED by self...
Note: the following resolution criteria seems to only be definitive for the app (mobile device). Web browser still does not show the two options
If you have an SD card inserted into the SmartHub
And you have SmartHub storage setting for SD Card 'Record Locally' toggled on
And you have SmarHub sotrage setting for SD Card 'Direct Storage Access" togged on
When you navigate to Library
Then you should see two dropdown options 'Cloud' or 'SmartHub' (SmartHub equating to your SD Card)
This happens a lot and if you kill the app and restart it sometimes it comes back online..
SOLVED by self...
Accessing Local Storage
