I cannot login to my Arlo account on my laptop. It says cannot recognise device so send a push notification, but I never get the notification on my phone and then it times out.
I've worked it out now. I had the wrong number including country code
Sounds like you have 2FA issue. A lap top is not a trusted device so it will send a push notification to you phone with a verification code. You should have your phone as a trusted device and would get the notification.
What is two-step verification and how do I set it up? (arlo.com)
I've tried setting that up but I don't get the notification on my phone.
Does the app work on the phone otherwise and have you made it a trusted device per the article.
Accessing Local Storage
