  • 5 Replies
  • 5228 Views
Floydbloke
Hopefully just a user error.
Using the Android app (v2.16.1_27099), clicking on the library I can't see an option to select the source so I can view locally stored clips ( I don't have a cloud subscription).
Admittedly I haven't tried to do this for while (had the system disarmed during Covid-19 lockdown) so I may be missing something simple.  I ejected the SD card and checked on PC, there are definitely clips on the card.
Any thoughts/ideas please.
5 REPLIES 5
michaelkenward
Sensei Sensei
Sensei
Have you set up direct storage access?
What is Direct Storage Access and how do I use it?
In the Android app, you should see the choice of cloud/local.
Local storageLocal storage
Unfortunately, my experience is that the link to local storage has a habit of vanishing.
Just another user
I've seen that also.  Force-stopping the app, and restarting it usually brings it back.
michaelkenward
Sensei Sensei
Sensei
Good advice.
It seems to work here too.
Just another user
LandJS
Mentor
Mentor
Yes, good advice and there has been a lot of good and helpful advice on here and people ready to help.  However that wouldn't be the main problem, the problem is that a top of the line product a year and a half old should not require this continual fixing.  To someone enjoying tech it might even be fun figuring it out but not what most people buy a security system for.  I know many people with other systems that never have to maintain their systems once installed.  Consider if you had spent more than $2000 on a TV and it had these constant issues and every firmware caused it to malfunction and you missed your shows, would you not be raging against the product.  When working they are a great system but I didn't buy them to work on, I used to enjoy finding and fixing computer issues but now I just want them to work and the same with my security.
Floydbloke
Thank you all.
Went through and disable then re-enabled SD card and direct storage access. Force-stopped and restarted the app and we're back in business.
LandJS is right, a premium-priced product shouldn't be this flaky.
  • 5 Replies
  • 5229 Views
