Can't login via Chrome web browser. Apps work fine
  • 2 Replies
  • 1971 Views
JoeEvnz
When I set up my Ultra system a month or so ago, I had this same problem. Try to login, enter the password and a page tries to load but then nothing happens.
I was able to figure out how to make it work back then (enabling Flash is part of it), but have since forgotten. I have enabled Flash, cleared the cookies, tried incognito...nada. Just wondering if another customer has figured this out.
To James C: please do NOT bother responding. This problem seems to come and go since 2017 and you just keep posting a circular link to this post: https://community.arlo.com/t5/Arlo/Is-anyone-having-issues-with-logging-into-Arlo-using-Chrome-and/t....
That post doesn't solve a thing. Go look at that and see if there is an answer listed anywhere. Spoiler alert, there isn't. But post after post with this same problem (over multiple months) James C rolls in and says "Solved" with a link to that post.
So back to the only helpful Arlo customer support, the customers themselves: what is the latest work-around for the ever-recurring can't get the login page to work?
Thanks,
Joe
P.S. Great product but just an utter hot-mess on getting support. I've never seen such a quality product rely on forums on how to use their product. Their video on how to extend the range of their hubs is flat out wrong. A Wi-Fi extender does nothing to extend the range of smart hub. It took me a few days of reading forums (and one purchased and then returned extender) to figure that one out! You need another smart hub if you need to extend your range.
JoeEvnz
Yep. I figured it out a few hours after my original post and planned to post the answer today.
Great example of how forum based tech support doesn't work. I googled Arlo login problems instead of Kaspersky (why would I google Kaspersky??)  and never found a post showing something that has been solved before but will continue to plague new customers in the future. I obviously found the solution a few months ago in an Arlo forum post, but there has to be a better way to find solutions to problems that keep repeating. This approach to problem solving is the best example of "re-inventing the wheel" I have ever encountered.
Here are the steps in order to help a future customer who has the same problems:
If you try to login and nothing happens: Turn Kaspersky off. Try again.
If you are logged in and your cameras wont show their live feed: Make sure you have Java enabled for that page (on Chrome you right-click on the little lock next to the URL.)
And thanks for your help jguerdat!  Another fine Arlo support tech...err I mean customer.
Let me guess - you use Kaspersky software, right? A quick search here on "kaspersky" will get you directions to whitelist arlo.com. It's a fairly long-standing Kaspersky issue.
JoeEvnz
  • 2 Replies
  • 1972 Views
