  • 5 Replies
  • 3794 Views
Skovringen
Can I connect Arlo 4k Ultra directly with wifi router and not use base station?
I have a large outside area to cover?
answer is needed asap
Thanks.
No.  You could use the Pro 4 (and Pro 3 Floodlight) instead.  Both can connect to your home wifi.  They are 2K (not 4K), but in practice there isn't a big dropoff.  The field of view is a bit smaller, and neither have the wind noise reduction on the audio.  But overall they are a reasonable substitution for the Ultra/Ultra 2.
Note that you will need a paid subscription for cloud storage, and local storage isn't possible w/o a base station.
5 REPLIES 5
Skovringen
so without the base station, there is no way to store videos?
dcfox1
Yes there is a way but  as @StephenB  said you need a subscription for cloud storage for recordings
Skovringen
But can i use my own cloud storage other than Arlo.?
dcfox1
No. Arlo's cloud is where the cloud recording in the library are stored.
  • 5 Replies
  • 3795 Views
