Cameras randomly stop recording
My upload speed for internet is 10.2mbps and download 232.6mbps
Also purchased 5 extra charge cords so all cameras are plugged in
Purchased a Solar charge panel and that does a very poor job of charging the cameras battery
If support can’t help me get system stable hope they will expedite a refund so I can get a system that records
Mikearends,
When you notice recordings are no longer occurring, Does your system give you any error messages? What is the LED behavior on your SmartHub?
The solar panel charges slower than an AC adapter, if you have a lot of traffic in the area and the cameras are recording frequently, this could mean the battery usage is outpacing the charge provided by the solar panel. You may need to try and reduce the amount of activity that camera records by adjusting position or sensitivity.
Same problem with 4 cameras, at least one of them stops recording every 5 days. They do record to local storage in most cases. I am trying to proactively reboot the base I very 3rd night to see if that helps, I can go a few more daisy before they stop responding.
SDB12345, Chrisk2
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Accessing Local Storage
